Manutenção do teu taco
Táctica, estratégia e conselhos!
Vamos a melhorar o nosso Pool!!
Mensagempor Antonio Neves » 13/Abr/2011, 23:55
para quem perceber ingles:
How To Maintain Your Pool Cue
One question we are asked most often is how to maintain and clean a pool cue. While the butt end of a pool cue will have lacquer or a Ultra violet finish on it, most high-end pool cues have no finish on the shaft at all, except for the first few inches at the joint. The finish on the main part of the shaft would prevent the shaft from sliding smoothly through a player's bridge and make it more difficult to clean and maintain.
To lightly clean your shaft, we highly recommend the Q-Wiz. The Q-Wiz is a double-sided rubber disc with micro grit that grabs dirt and oil, yet does not bite into the wood of the shaft; unlike sandpaper which can over time alter the taper and millimeter of the shaft. For a deeper clean, a liquid cleaner such as Q-clean or Diamondback Shaft Cleaner can be applied to get additional residue out of the pores of the wood. The opposite side of the Q-Wiz has a texture similar to that of leather and does a fantastic job at burnishing the shaft, making it silky smooth. After using the Q-Wiz for a while, your Q-Wiz may accumulate dirt/residue. The accumulated dirt can be removed from the Q-Wiz with a little dish soap and an old tooth brush.
Burnishing the shaft is the most important step in maintaining the shaft and preventing warpage. Since oils, sweat, cleaning fluid or simple humidity can cause the pores of a shaft to swell open, making it more susceptible to deeper penetration of atmospheric moisture. One should burnish a shaft frequently. To burnish a shaft, simply use a piece of leather, the Q-Wiz, or even an old towel. Buff until the shaft is warm to the touch from the friction. This will also cause the shaft to feel smoother.
Inevitably a ding will appear on a cue shaft that is used frequently. To remove dings moisten a small piece of tissue and lay it over the ding for 15 - 30 minutes. The moistened tissue should be balled up to the approximate size of the ding. This will cause the wood to swell and the shaft can then be burnished. For larger dings, some players have reported great success with the Cue Doctor Dent Buffer. It is made of borosilicate glass to assure consistency. When rubbing the glass rod over the dent a light clicking sound can be heard, continue to rub vigorously until this sound can no longer be heard and the dent is smoothed. The Doctor Dent Buffer can also be used to shine Irish linen wraps.
To clean the lacquered or UV finished areas of the cue. We recommend car wax with Teflon, since the Teflon will help to repel dirt and salt from a player's hands.
Lastly, part of cue maintenance is maintaining the cue's tip. For the cue used for play (not break or jumping) one should keep the tip with the same radius as the edge of the dime. Simply hold the edge of a dime up to the cue tip. The tip should follow the same curve. For keeping chalk on a tip, we recommend a Tip Pik or Bowtie Tip Tool . The spikes on these tools has less tendency to needlessly remove leather or unduly soften the tip surface for the application of chalk. A Tip Tapper can be used if the player keeps in mind the dime radius shape to be maintained, by tapping evenly over the entire surface of the tip. If a tip becomes flat we recommend a Willard Tip Shaper or the Bowtie Tip Tool because both will provide the correct dime radius. The more often a tip is shaped the sooner it will need replacement. Still, allowing the tip to flatten will cause the cue to have increased deflection, cutting down on the performance of the cue. A player must also watch for a tip that might mushroom over time or after shaping. A mushroom is a lip or flaring over the edge of the ferrule, in which the leather begins to break down. If there is only a slight flare one might simply be able to burnish the tip to remove the mushroom. To burnish a tip, apply a little moisture to the edges of the tip using a quick twisting motion of a Porper Tip Burnisher or a stiff piece of leather until the tip's edges take on a deep brown color. The color indicates that the edges have been hardened. If there is a large {mushroom|lip} over the ferrule, one should use a Porper Mushroom Grazer to remove the excess tip and then burnish the edges.
________________________________________
Re: How To Maintain Your Pool Cue
Mensagempor jrmosantos » 14/Abr/2011, 01:24
Uma pergunta que nos é pedido na maioria das vezes é como manter limpa e um taco de bilhar. Enquanto o fim de extremidade de um taco de bilhar terá laca ou um revestimento ultra violeta sobre ela, a maioria dos tacos de bilhar high-end não têm acabamento no eixo em tudo, exceto para os primeiros centímetros da junta. O acabamento da parte principal do eixo impediria o eixo de deslizar suavemente através da ponte de um jogador e torná-la mais difícil de limpar e manter.
Para limpar o seu eixo levemente, recomendamos a Q-Wiz. O Q-Wiz é um disco de borracha dupla-face com granalha de micro que agarra a sujeira e óleo, mas não morder a madeira do eixo, ao contrário lixa que pode alterar ao longo do tempo a vela e milímetro do eixo. Para uma limpeza mais profunda, um aspirador de líquidos, tais como Q-limpo ou Diamondback eixo de limpeza podem ser aplicados para obter resíduo adicional para fora dos poros da madeira. O lado oposto do Q-Wiz tem uma textura semelhante à do couro e faz um trabalho fantástico no polimento do eixo, tornando-o macio e sedoso. Depois de usar o Q-Wiz por enquanto, o Q-Wiz podem acumular sujeira / resíduo. A sujidade acumulada pode ser removido da-Q Wiz com um pouco de detergente e uma escova de dentes velha.
Polimento do eixo é o passo mais importante na manutenção do eixo e prevenção empenamento. Desde os óleos, suor, umidade fluido de limpeza ou simples podem causar os poros de um eixo a inchar aberto, tornando-o mais suscetível à maior penetração da umidade atmosférica. Deve-se polir um eixo de freqüência. Para polimento de um eixo, basta usar um pedaço de couro, o Q-Wiz, ou mesmo uma toalha velha. Buff até o cabo está quente ao toque da fricção. Isso também fará com que o eixo para se sentir mais suave.
Inevitavelmente um ding aparecerá em um eixo de sinalização que é usado com freqüência. Para remover dings umedeça um pequeno pedaço de tecido e colocá-lo sobre o ding para 15-30 minutos. O tecido umedecido deverá ser enrolado até o tamanho aproximado do ding. Isso fará com que a madeira a inchar eo eixo pode ser polido. Para dings maior, alguns jogadores têm relatado sucesso com o doutor Cue Dent Buffer. É feito de vidro de borosilicato de assegurar a coerência. Ao esfregar a vareta de vidro sobre o dente uma boa luz pode ser ouvida clicando, continue a esfregar vigorosamente até que o som não pode mais ser ouvido ea pancada é suavizada. O Doutor Dent Buffer também pode ser usado para brilhar envoltórios de linho irlandês.
Para limpar o laqueadas ou UV terminou áreas da pista. Recomendamos a cera do carro com teflon, pois o teflon vai ajudar a repelir a sujeira eo sal das mãos de um jogador.
Por último, parte da manutenção de sinalização é manter a ponta do taco. Para o taco usado para jogar (não quebrar ou saltar) deve-se manter a ponta com o mesmo raio que a borda da moeda. Basta manter a borda de uma moeda até a ponta do taco. A ponta deve seguir a mesma curva. Para manter-se giz na ponta, recomendamos uma Pik Dica ou Bowtie dica de ferramenta. Os pontos sobre essas ferramentas tem menos tendência para remover desnecessariamente couro ou indevidamente amolecem a superfície da ponta para a aplicação de giz. A Tapper Dica pode ser usado se o jogador tem em mente o raio centavo forma a ser mantida, tocando uniformemente sobre toda a superfície da ponta. Se a ponta se torna plana recomendamos uma Willard Dica Shaper ou a gravata dica de ferramenta, pois ambos irão fornecer o raio centavo correta. Quanto mais vezes uma dica é moldada quanto mais cedo ele vai precisar de substituição. Ainda assim, permitindo que a ponta para achatar fará com que a pista tenha aumentado deformação, reduzindo o desempenho do taco. Um jogador também deve procurar uma dica que pode cogumelos ao longo do tempo ou após a modelagem. Um cogumelo é um lábio ou queima ao longo da borda da ponteira, em que a pele começa a quebrar. Se houver apenas uma folga leve pode simplesmente ser capaz de polir a ponta para remover o cogumelo. Para polir uma dica, aplique um pouco de umidade para as bordas da ponta com um movimento de rotação rápida de uma Sugestão Porper Lustradora ou um pedaço de couro duro até que as bordas da ponta de assumir uma cor marrom escura. A cor indica que as arestas foram endurecidos. Se houver um grande cogumelo {|} lábio sobre a virola, deve-se usar um Porper Mushroom Grazer para remover o excesso de ponta e, em seguida, polimento das bordas.
jrmosantos
Mensagempor MEZZ Portugal » 14/Abr/2011, 03:00
A atitude de traduzir para portugues é de louvar, desde ja o meu aplauso. :palmasss :palmasss :palmasss
Mas a tradução...... é muito má.
Ainda assim obrigado mais uma vez pelo trabalho a que se deu. :palmasss
MEZZ Professional Cues
MEZZ Portugal
Taco de Jogo: Mezz Ace 806
Taco de Jump: Mezz Air Shooter
Modalidades: 8,9&10 ball
Taqueira: Mezz NPC 35
Mensagempor pedroteixeira » 14/Abr/2011, 06:32
MEZZ Portugal Escreveu:A atitude de traduzir para portugues é de louvar, desde ja o meu aplauso. :palmasss :palmasss :palmasss
sem duvida , mas teve a humildade de pendar em quem não sabe ingles paras ler um texto tão elaborado
mas mesmo com alguns erros , uma tradução bem ilucidativa para todos .............obrigado :palmasss
Mensagempor Sérgio Mendes » 16/Abr/2011, 13:28
Uma tradução com lista de compras:
Manutenção do taco.rar
(72.64 KiB) Transferido 947 Vezes
Leonardo da Vinci
Sérgio Mendes
Mensagempor Antonio Neves » 16/Abr/2011, 16:24
Sérgio Mendes Escreveu:Uma tradução com lista de compras:
Sergio, tens de me dizer onde arranjas-te site para traduzir a cena tão fidedignamente :palmasss :palmasss :palmasss
, eu não o fiz pois achei que não ficava grande coisa.
Mensagempor Sérgio Mendes » 17/Abr/2011, 13:37
O site chama-se: "Facilidade em inglês e dedos rápidos no teclado (informático)."
Bom post, o teu.
Parece em geral ser a forma mais correcta desmistificando algumas avarias na manutenção do taco.
Em relação à lista para gastar guito, em tempo de fmi, se calhar é melhor seguir o exemplo do Souquet.
O pai inventa-lhe algumas engenhocas baratas.
Leonardo da Vinci
Sérgio Mendes
Mensagempor Antonio Neves » 17/Abr/2011, 13:41
Sérgio Mendes Escreveu:O site chama-se: "Facilidade em inglês e dedos rápidos no teclado (informático)."
Bom post, o teu.
epá, então se assim é, obrigado pelo trabalho a que te deste. :palmasss :palmasss
bem me parecia que a tradução estava demasiado fidedigna para ter sido feita num site :duvida :duvida
Mensagempor Sérgio Mendes » 17/Abr/2011, 16:57
Quem corre por gosto cansa-se menos.
O Google Tradutor ou outros são muito úteis para quem tem dificuldade a inglês (com termos técnicos).
Copiar, colar e instantaneamente ler ou até ouvir um texto é muito prático, e é suficiente para ter uma boa compreensão sobre o assunto.
Mas para enviar para alguém como resposta sobre o assunto, guardar o documento ou colocar num site, não é a mesma coisa.
A sola demasiado alta ou em forma de cogumelo, a vara ter pequenas mossas... são motivos de distracção e sabotagem de uma boa execução.
Eu é que agradeço, o que é na minha opinião, o melhor tópico sobre o assunto.
Leonardo da Vinci
Sérgio Mendes
Mensagempor MEZZ Portugal » 19/Abr/2011, 04:15
Bom Trabalho sérgio. :palmasss :palmasss :palmasss
MEZZ Portugal
Voltar para A aprender...
